A/C Manifold Gauge Readings
Next I pulled an initial vacuum to 29 and let it sit for 10 minutes to check for leaks. Good to go. Pulled vacuum for an hour, then recharged.
I ended up using all three cans of r134. When you purge or open the lines, some is lost.
I did check at 24oz and the pressures were low, so added third can.
This is at idle in a shaded garage, overall pressure seems low for the ambient temp. I did give her some throttle, but pics are at idle.
If you take the DS headlight out, may be a good time to add something abrasive resistant to the ac line going towards the switch in front of battery. I noticed there was protection that had decayed.
First day of driving results, it's better but not perfect. Morning commute was standard, 40 ish at the dash.
The largest improvement was in the evening, I'm getting 42-46 at the vent within a 15 minute drive. For reference, internal temps were 120 at startup. I lowered windows to get out the hot air and left the a/c on external vs recirculate for a couple minutes.
I definitely noticed a drop in dash temperature when driving between 2-3k RPM. However, when I park at idle it will hold 44 dash. I definitely get lower vent temps with the fan speed on low, but that position really does not move enough air. When fan is on high, temps increase 2-3 degrees.
FWIW, radiator temps are slower to increase with this condenser. When I first started this experiment, highest I ever saw on the OBD gauge was 194 degrees. I added foam around the old Denso condenser and was quickly hitting 197 in stop and go traffic. I DID NOT add foam to the Nissen condenser install, and I'm back at 194 top temp. It just seems to take longer to reach 194.
I think my next move is to pull the fan clutch and replace with 15k oil along with swapping in an OEM A/C belt. I'm getting shards of rubber thrown in the engine bay, but cannot tell which set of belts. The A/C belt was originally loose (55 ft/lbs), but I tightened it to FSM spec on the high end (90 ft/lbs). Alternator belt tested within limits, however the belts are definitely not sitting above the pulley grooves per FSM.
