I've went through many threads and did not find an answer for 2006 LX470.
My A/C does what many have seen, from time to time starts blinking and no cold air, so I have to click on/off button on the navigation to make work again.
Has anyone found out as why 2006 LX470 does not have MG CLT under the fuse box under the hood behind battery? See the pic.Or is it in a different location?
My AC does this from time to time and R134a level is fine in the compressor. I've thought it was a bit low and after bit charging it (overcharging) it did not work, which makes sense. Then let some out back to norm and fine, but from time to time driving for longer periods it stops and does the A/C button flashing.
The only code from AC diagnostics is rear blower which should not matter especially when it's not in use and it actually works.
