I am looking for a A/C bracket that goes on a 2F with the alternator on the passenger side.
I assume the compressor goes below the alternator.
you'll need the motor mount as the compressor mount is incorporated into the motor mount, then there is a tensioner piece that attaches to the lower alternator bracket.
other questions would be are the holes in the alternator bracket for the tensioner to bolt to
do you have a 3 groove crank pulley?
I've got all the parts but you need to know all the stuff you need.
other questions would be are the holes in the alternator bracket for the tensioner to bolt to?
YesWhere are you moving the battery to? The AC motor mount is not compatible with the battery tray support.
Can’t you just move the tray down closer to firewall?Where are you moving the battery to? The AC motor mount is not compatible with the battery tray support.
I am putting in a 2F from a 78 model. Your correct. It is not a stock.
Do you also have the stock compressor?
Do you have the brackets and tensioner?I do have used compressors, but hard to say what condition they are in.
I've got all of the parts,
a/c motor mount
a/c comp
a/c tensioner
alternator mount and tensioner
as Mark stated above, you'll need to modify the battery mount
Hey Tommy ,
U will need this too :
It Bolts to the Front Motor mount ( Compressor style ) @3_puppies has for u with a 8mm x 1.25 / 12mm hex-tool size bolt
u will also need Both Correct Lower Radiator Hoses For a Factory A/C Equipped 2F truck , they are different & Unique ,
I Sourced Mine from SOR.com
OEM Radiator Union Pipe with Heater Split-off - For FJ40 or FJ60 with A/C
