- Thread starter
- #61
Por nada compadre!!Gracias muchacho!
Did you put any protective materials under the electrical tape here?
I've noticed this is a problem area and was going to see what we could do to protect it better prior to putting it back as well.
We use fire sleeve from Aircraft Spruce. Slit it so it'll slide over the harness, secure it with zip ties, and then tape.![]()
What inner diameter do you recommend? Saw a few options, at that price better off asking then ordering first.
Bill bust out some OE foam for a few squeaky trim pieces.View attachment 2346964
You should remind Bill about the noise kit Toyota has from Nitto Denki. It’s the bees knees.
I rebuild all the foam for HVAC systems using this kit. HTH.![]()
The AE102-14, which is 7/8" ID
Eaton Aeroquip Firesleeve AE102-14 | Aircraft Spruce
Eaton Aeroquip Firesleeve AE102-14 Aeroquip Firesleeve was specially developed to meet the fire resistance requirements of FAATSO - C53a OR TSO - C75. May be used for all fuel, oil, hydraulic, fire extinguisher & propeller feathering liwww.aircraftspruce.com
It isn't cheap but your 80 is so worth it!![]()
I really like working with Mary at Precision. I just wish I could sweet talk her into a bigger discount.The tint on the rear hatch wasn't being cooperative, and we didn't want to damage the defrost element, so we took the rig over to our pals at Sweet Window Tinting. They do the best tint work we've come across, by far. If you're looking for tint, or protective paint film, we can't recommend them highly enough. We also needed to do a parts run to Precision Toyota so it was a perfect opportunity to test the A/C in 100 + degree heat...in Tucson traffic. Icy cold, no surprises.View attachment 2348385
The Bighorn Fire was putting up some serious smoke when we dropped the rig off at Sweet Tinting. Hopefully monsoons start soon.View attachment 2348404
