[quote author=cruiserdan link=board=2;threadid=10728;start=msg96564#msg96564 date=1075338490]
There is no factory installed passenger side airbag shut off switch in the 80 or 100 series Cruisers.
Qualifying persons can petition the NHTSA for permission to obtain shut off switches. They are available as passenger only, driver only, or both sides. The permission granted depends on individual owner's needs. You do not get to "pick" what you want. Single shut off switches run about 170 bucks and a double is about 300 bucks. It must be installed by a participating dealer or installer.
If you are interested to see if you qualify check this out:
www.nhtsa.dot.gov
D-
[/quote]
To have a shop install the switch for you, you must have the approval of the NHTSA mafia. You can disable your airbag if you wish, without any government approval. There are lots of places that sells switches to individuals along with the instructions on how to install it.
You can always fab you own switch. The only difficult part is to match the resistance of the airbag to the switch so that the airbag computer doesn't think that the airbag is malfuntioning.
NEVER USE A METER TO MEASURE THE RESISTANCE OF AN AIRBAG. THE CURRENT FROM THE METER COULD TRIGGER THE FIRING MECHANISM OF THE AIRBAG!!!
Use a POT in place of the airbag to tune the system until the airbag computer thinks there is a funtioning airbag (airbag light is off). Most airbags are in the 2.5-5 Ohms range. Measure the POT and put in a resister with the same resistance in place oif the airbag. Make sure the resister is rated for least 5 watts.
You can leave the resistor in place to permanently disable the passenger side airbag or fab a switch with the proper resistance to turn the airbag on and off.
