- Location
- United States
I'm contemplating selling my '97 LX450. NO RUST! It's been a north Texas truck it's whole life. When I bought this truck, in Oct. of 2013, it had 150,000 miles on it and it appeared to have never been off road. It had zero scratches, zero dents, zero dents/scratches on undercarriage and zero accessories except grill/light guards. I searched a long time to find, what I believed was, an unmolested and babied truck. I believe I'm the 3rd owner (first in Lubbock, 2nd in Irving and now me in Waxahachie). I have pic's from the day I bought it for those interested. 203K miles but will go up as it's my DD. I'm a bit hesitant as I've put a bunch of time & money in it & wouldn't hesitate to drive it across the country, again. It runs & drives great. It has desert sand Monstaliner over the entire body.
Lots of PM done to it & aftermarket parts added.
Parts added/upgraded:
All Monstaliner'd
ARB front replacement
Smittybilt 10K Winch
OPOR rock rails
LED light bars on bumper
Rear Aussie Locker
4x4 Labs single rear tire carrier swingout
OME 850/860 complete lift kit w/caster correction via bushings
DIY "Moose" roof rack
CDL switch added
Factory alarm removed
Kenwood double DIN head unit w/back-up camera & hands free phone
Door speakers replaced w/Pioneers
Dual battery set-up completed except a second battery hasn't been added
Multiple USB/ cigarette lighter plugs front & rear
All LED interior lights
WeatherTech floor liners in front 2 rows
295/75/16 Toyo AT II tires
Stock wheels painted black
Uniden CB in the ashtray
Scangauge
Firestik antenna w/splitter so stereo & CB use the same antenna
flares removed
ABS/LSPV delete (still have everything that was removed)
I'll add more items to this list as I remember them
PM performed/ parts replaced (all Toyota parts unless noted):
All U-joints
Fusible Links
Rem. Starter
plugs
cap
rotor
dizzy o-ring
oil pump gasket
O2 sensors
belts
A/C idler pulley
tranny fluid drain/refill
t-case drain/refill
Diff's drained & refilled
brake fluid flushed
Koyo radiator
All radiator hoses replaced
full coolant system flushed
Upgraded fan clutch w/fluid
Brake booster (aftermarket)
Power Stop slotted & drilled rotors front & rear
Power Stop "HD" pads in rear, Power Stop "truck" pads in front
PHH work around w/Gates Green stripe
2nd line by PHH
Many vacuum lines
Rear wheel bearings repacked
Rear axle seals replaced
Front axle seals replaced
Front wheel bearings repacked
most exterior bulbs
lots of wiring routed for lots of accessories
Getting a new registration/ inspection this week
The bad:
Valves sometimes rattle (probably just need adjusting, IDK)
A bulb out in the dash for the A/C light
A crack in the center of the dash
A 1" x 4" shallow dent in right rear quarter panel @ the tail light (easy fix but I haven't fixed it yet)
Monstaliner has a line in it going around the truck from doing the bottom half then a month later doing the top half (I planned to lightly sand the line & do a light layer over it to make it disappear)
Driver seat bottom has been recovered but the rest of the seats haven't (some cracks but no tears)
Front seats won't go forward/backward (they need the plastic gears replaced)
Factory antenna doesn't function (see above for antenna info.)
Plast-dip on ext. door handles needs to be removed/redone
Speedometer/ odometer works but trip meter does not
I'm trying to be as honest as possible w/this list. Most of these items are non-issues but I want to be 100% up front about any/all problems.
This is an expedition/overland built rig that will go just about anywhere. I built it for all types of terrain & dependability. I'll try to post pic's if I can figure out how since I don't have PB anymore. PM me your email or phone number & I can send some.
Asking$13,300 obo $12,500. Would trade for a moderately built low mileage 1st Gen Tacoma. I will not accept irrational lowball offers so please don't waste your time. If it doesn't sell, oh well, I'll just keep driving & modding it!
Thanks for looking!
All Monstaliner'd
OPOR rock rails
Rear Aussie Locker
CDL switch added
Scangauge
flares removed
All U-joints
Fusible Links
Rem. Starter
plugs
cap
rotor
dizzy o-ring
oil pump gasket
O2 sensors
belts
A/C idler pulley
t-case drain/refill
brake fluid flushed
Koyo radiator
2nd line by PHH
Many vacuum lines
most exterior bulbs
The bad:
Asking
Thanks for looking!
