- Thread starter
- #41
Been reading too...sounds like getting the bias toward the rear is an issue as well. Likes to stop on the fronts.
Front axle rebuild will run about $1000 if you do it correctly. Folks on here claim it can be done for $280. Didn't happen for me. ...
... MY axle rebuild was RCV axles/birfields, all new seals, wheel bearings, trunnion bearings, steering arm studs/cones/nuts, spindle nuts/washers, moly grease, 85W-90, Lucas RedNTacky2. To some, an axle rebuild is new seals and gaskets only. The kit for those is about $280. I did NOT rebuild my third member in front or rear. ...
Rear axle rebuild will run about $200. That's about right....
Brakes (Pads, Rotors) will run about $500 just for the parts. Calipers are about $100 each.
Transmission service will run about $100 every couple of years.
... These trucks LIKE OEM parts and the aftermarket stuff is usually crap, not like the old Chevy's aftermarket stuff. ...
So, yours was clapped out, unmaintained, POS, and you're inferring that everyone one needs to spend $1000 on their knuckle reseal job or it's not done correctly? I beg to differ, have done a ton of them for about half of that, including labor, out the door. Many of them have 200-300K miles, locked, 37" tires and wheeled often. Most of those still have the original, birfs, axles, spindles, wheel bearings, etc and are solid, reliable. If doing it yourself, can often be done "correctly" for ~$200.
BILT4ME:
I don't know how to do multi-quote, so bear with me.
Yes, mine was clapped out. My truck has piss-poor maintenance by the PO. If you read a later post, I clarify that. It comes down to interpretation of "rebuild". No third member rebuild costs in mine.
TRU:
I would say that is a bit light, just the pinion and carrier bearings are more than that? If you're just talking about rear wheel bearing repack, that is about right with labor.
BILT4ME:
I am referring to a wheel bearing replacement and new seals, NOT a including a third member rebuild.
TRU:
I guess if your stuff is clapped out, we rarely replace rotors or calipers, so brake service is pretty cheap.
BILT4ME:
Yes, again, my stuff was clapped out. Rotors were horribly warped, pads were shot, calipers were leaking, TRE's shot, Steering arm studs falling out (3 out of 4 on one side)
TRU:
With labor, maybe?
BILT4ME:
No, actual cost of oil. I did the flush with 20 QT of oil which is about $5 per QT of trans oil retail. ALL labor was done by me in ALL instances. I don;t pay shops to do stuff unless it is machine work, body, or paint. I am not a shop, I do this because I can and enjoy it. I do not do it for additional revenue, but I would if the opportunity arises.
TRU:
Depending on how you shop. For somethings there is good aftermarket parts available and many of the OEM suppliers now sell in the aftermarket. So a smart shopper can save significant cash and still use quality parts, equal to dealer.
Define "kneepads"
At any rate. Let's take this from another angle shall we? No repairs...everything running way it should...just maintenance.
Ok with that in mind, how much per year so you spend just maintaining your rigs, and how many miles per year do you drive?
Thanks all!!! Been a 10 year journey for me. I don't let go easy.
I was just thinking the same thing. Slee has a cost of ownership article on their website. Buying a 20 year old vehicle of unknown history has its inherent risks. I purchased sight unseen for a thousand more than the owner paid for it. It was a risk I was willing to take and afford at the time. Base lining the fluids and all the preventative replacement parts add up quickly. Research and read as much as you can before jumping in to the water. It is a brilliantly over engineered platform that is outdated by today's standards. I love being outdated.if you need to take out a loan to afford this truck, you can't afford it; not the maintenance and not the repairs, either - sorry to be so blunt, but it's the truth
10-11¢ per mile, including tires? s*** that ain't bad at all.
hell, no - where are you getting that number from ?
our 80 sees at best 5000 miles a year if that much, the LX definitely sees less than 3000
insurance on each is close to $1000/year - and I haven't even bought gas or any parts yet - that's $0.2/mile on the 80 to start with, and $0.33 on the LX - without having driven either of them out of their respective garage yet . . .
That was just maintenance including tires averaged.
nope, tires will cost you extra
