94 LC Check Engine Code 12 (1 Viewer)
Can someone give me the description for check engine code 12 for a 94 LC? I used the jumper method and got codes 12 and 71. 71 I was able to track down and determined it to be a cracked EGR hose, but I have had not luck with code 12. Thanks.
RPM signal
Trouble area:
distributor cicuit
distributor
ECM
Newbie question here: Can to get the check engine error without a specific device? or do you need a Toyota decoder (whatever the correct term is) to tell you what code the light applies to?
Your 96 is OBD II which you need a code reader to pull the codes. OR take it to Vatozone (or any other national chain) and they can pull the codes for you- most do it for free.
On pre 95 - you can pull your own codes with a SST...aka a paper-clip. ;) Yes...a paper clip. It is a nice feature...along with the superior tranny! :D :cool:
Thanks. I believe I triggered code 12 when changing the distributor cap and initially failing to plug the electronics back in to the distributor.
Remove the negative battery terminal for 5-10 minutes and re-install. It will probably clear your code.
