Just tried mine with the "wire jumping method." I hope that it clears my Code 71 CEL!!
About 500 miles in, with just the wire jumper, I'm saying no resistor necessary....![]()
I am not sure I really understand what the EGR system does, but I do know that I don't care that much now that mine is taking a dirt nap.
Should I try to cap the two ends of the wire now though since I live in the rust belt and those will probably be exposed for awhile. I bought some big shrink wrap pieces and plan on experimenting with sealing an end on one before slipping it over the electrical connection ends.
I got rid of the egr and pair system. Run the o2s up where the pair was. Got rid of the jungle of vacuum lines and vsvs under the manifold. Now run one single vacuum line to the fuel pressure regulator, all others are capped, and can run the heater return pipe from 95 and up to eliminate the extra heater hose our 93 94s have. I still have the charcoal canister but vent it to atmosphere instead of the engine since its switch is gone. Truck runs awsome
None of the stuff I have pulled is needed on a obd1, I am a aviation mech by trade and worked land cruiser specifically too as work. I don't plan on getting rid of my truck and prob majority of people might think getting rid of stuff is silly. But for me it makes the engine way more simple , it runs way smoother, I have no vacuum lines to worry bout or change which is not a super big deal, I like the o2s up in the manifold because easier to change and stay cleaner as far as the outside. I have no hot egr running on my harness and I don't have to do emissions in this part of Colorado. I have no vsv switches to worry about. In my opinion I have way cleaner engine and less systems to trouble shoot.
So I tried this approach and the CEL is still there on my 94 with code 71. Do I have to drive for 15min or something before it's turned off? What else could it be?So, after nearly going blind reading EGR posts, and the fact that my truck runs SO GOOD, I've got no interest in going any further than I have to to try and get rid of the CEL...
From what I can gather, I can render the EGR inoperative by doing this...
This seems to have worked, since after a trip to town, with a little 10 mile highway jaunt, the EGR pipe is cool. Truck runs perfectly, no noticeable change. I like the idea of no hot exhaust gas running back thru my motor, and maybe saving the HG by #6 would be a big bonus...
The light came back on, and I remembered someone's "Redneck Fix" that involved jumping the temp sensor plug, so I've done this...
Next step is Radio Shack for the resistor, I guess, if that trick works on the '94. But I've read so much of this stuff, on so many trucks, that I'm looking for some feedback telling me that I'm on the right track here...
Thanks again guys, I'm off to try it out...
Thanks. How do you clear the code on this lovely 94 beast?did you clear the code before driving? if you didnt eventually it will clear its self if theres no fault seen by the computer and that will take a little while to happen.
thanks. I disconnected the negative cable of the battery for 15min and it worked.you can disconnect the battery or pull the efi or one of the ecu fuse, i dont rember which one it is off hand. pulling the fuse is preferred since it wont clear the radio memory
