Look under your truck from the front corner. You will see a diff support on both sides of the front diff.
If it is cracked, it is obvious.
Example of mine :)
Hey i would also check that the mounting surface where spacers attach to the hub is hit with a wire wheel to make a flush mount. I don't think it's your spacers if the mounting surface is clean.
