Just picked up a '91 RHD Prado Turbo Diesel from Japan.
Drove it for a day and realized the rad had a leak. Got the rad pulled and fully refurbished top to bottom, new cores and everything.
Drove the next day for 8.5 hrs up and down Mtn. passes... the Prado was purrin' like a kitten, with the temp gauge sitting at the same spot the entire time (little lower than middle).
Day after this, drove for about an hour, then up a steep, sustained hill running 25-2800rpm and the temp jumped WAY up (but not in the red). Got home, popped hood and the overflow tank was pretty full with coolant leaking out the overflow hose.
Next day, attempted the same hill, same RPM, and temp jumped again, but not as high. Hmmmmm.
Today, checked levels in the morning while cold and overflow tank was empty, so added some coolant direct to rad, but it only took a teaspoon or so, left overflow empty. Then, I tackled the same hill after driving the truck for a hour or so... this time, the temp crept up slowly, and then shot up to the red suddenly... I let off the gas, it came back down... crept up hill further, it was mellow, and then jumped up into redzone again! As I got home, I checked levels again, and overflow was full, with coolant bubbling.
Any suggestions? Wrong coolant to water ratio? Are there specific diesel coolants to use? I'm new to the whole diesel thing, don't mind me, but super excited about my new Prado.
Any suggestions would be fantastic.
Cheers.
Cheers.
I'm trying to come up with a plan of attack for my Prado 'issues'... How does one determine if the head IS truly cracked? I have an appt. at a shop, will a mechanic be able to determine this?
