91 Land Cruiser Starter Failing (3 Viewers)
Salt Lake City
Hey all,
I know this has probably been covered on here before so I truly apologize in advance, but I just want to make sure I'm approaching this the right way.
My 91 (now with 274k miles) has had intermittent starting issues going back to about 2021. I've always been able to fix it by having someone else turn the key while I hit the starter with a hammer, so this obviously points to something wrong with the starter. I have full service records back to 1991 and it has never been replaced/rebuilt before. Recently the problem has been getting more consistent, with it maybe happening every 5-10 starts, and sometimes when I'll turn the key it takes multiple seconds for anything to happen, which I assume is related to the same issue.
If someone can confirm that this is in fact the starter and not something I haven't thought of, would the rebuild kit fix this kind of issue? Is the rebuild kit still available? Or should I drain my wallet and just replace the starter entirely? I want to keep everything OEM Toyota parts and I assume the OEM starter is not available anymore. The only factor I guess is if the rebuild kit will solve this problem I'm having.
Appreciate any wisdom, and also any trash-talking as this has probably been asked before. Thanks in advance
just put a new set of brushes / plunger in it and youll be fine
it sounds like the plunger is sticking plus if original the contacts would likely be in need of a refresh
its a very simple job
Okay cool. So will need brushes, plunger, and contacts? Or do the contacts just get cleaned?
Does anyone know the part numbers for this stuff?
Go to Partsouq dot com, type in your VIN, that will bring up the parts diagrams for your entire vehicle. Then start searching,
easiest method is to click on Search, then type in Starter, then click on the diagram, then look at the parts. The rebuild kits however may not
be listed but it will get you in the ballpark.
Or, go to any online Toyota parts dealer and search for Starter.
Here's one link, a completely re-manufactured Toyota starter for a 1991 FJ80 is not that much more than the cost of the two rebuild kits
you need. However those kits would only replace the contacts, plunger, and a few other small parts. The bearings, armature, brushes
are not included in the rebuild kits. There are other components inside a starter that can wear ie: the clutch, pinion gear, etc.
Search my click/no start thread. I think the contact p/ns are in there.
I recommend you do this yourself and don't buy a rebuilt. I was disappointed to find that my starter was rebuilt, was I got it out, and the reason the contacts were shot was because the rebuilder skipped the steps in the FSM to seat the contacts. This was abundantly clear by the unevenness of wear. It wasn't even hard to do.
Agree, depends IMHO on whether your starter is the original or an aftermarket starter. But then again if the OP's starter is the original it's 34 years old.
Compared to buying an aftermarket rebuilt starter it may be a better route to replace the contacts and plunger of your original Denso-Toyota starter (assuming your starter is the original). One reason however to buy a Toyota remanufactured starter (from a Toyota dealer) is that it's currently available (for a 34 year old vehicle). AFAIK they aren't reman'd in Japan anymore but still would be a better choice than most no-name aftermarket starters.
From above, here's the part numbers for the rebuild kits:
28235-35080 plunger
28226-72080 battery side terminal kit
28226-72010 motor side terminal kit
So to purchase the parts above might cost ~70-85 (plus taxes and shipping) for contacts and plunger and a few other small parts.
So you can partially rebuild your starter for ~$70-85 plus shipping and taxes, or replace your starter with a new OEM Toyota Remanufactured starter for ~ $85-140 (depending on where you buy it, discount, plus shipping, taxes).
IMHO having completely remanufactured a Toyota-Denso starter myself I found that the original grease after 20+ years dries out, that's both
inside the bearings and the gear reduction area (clutch mechanism, pinion shaft, gears, bearings). Also the brushes and the armature both wear
from use.
None of those parts are replaced with the kits above and nothing internally is cleaned or re-greased. Then there's corrosion of the case and long bolts,
large O-rings for the case that are not in the kit, a large rubber grommet/boot that comes apart with age, etc, etc
So replacing the contacts and plunger may get more years out of the original starter but that isn't the same as a remanufactured Toyota starter where all worn parts would be replaced with new DENSO-Toyota parts.
28235-54380 : ~$20-25 (Price depending on discount, where purchased)
28226-72010 : ~$30-35
28226-66060 : ~ $20-25
Those part numbers are for the 1FZ-FE starter. The OP has a 3FE.
28235-35080 plunger
Fixed it.
@Demonic92 : Main point I was making, IMHO, is that it's better in the long run to buy a new TOYOTA Remanufactured starter while they're still available.
Thanks guys. I think having a Toyota reman would be great too, and I can shelf my current one and then have an extra that I can rebuild if I want to.
The Toyota brand reman starter is still available, but there are multiple different part numbers. Is this just related to the different versions (cold weather, etc.) that they offered? If so I assume I have to determine which one I have and replace it with the same one?
For a 1991 FJ80 with the 3FE engine it appears that the only starter available from Toyota is 28100-60070-84 (-84 means its a 28100-60070 starter that's been
re-manufactured). All that is assuming your current starter is defective. You can pull it off the vehicle and take it to a auto parts store to have it checked.
@Demonic92 : Take a photo of your current starter including the part number sticker if it's still there and post it up.
been there done that. Been hitting my starter with a crow bar for about 6 months to a yr and finally fed up with popping the hood and have someone crank. Went and replaced the plunger with a kit on my OEM starter and problem persists. I ended up putting in a ford solenoid and bypass the NSS. Problem solved. I am not interested in factory fix, so the FORD solenoid is the best thing that has happened with my no start situation.
The sticker is probably still there, but my starter is so covered in grease and dirt that I am not sure where to look. Someone said look from the driver's side bur I can barely see it from the driver's side, both from the top and underneath. I guess I'll hit it with a can of brake cleaner and maybe someone here has wisdom on where the part # is on a 3FE starter?
@Demonic92 : brake cleaner (solvents) might remove any remaining letters. Just about any cleaner/soap (non-solvent), water, and paper towels or a rag would work.
Your starter (on a 3FE engine) would be located on the right rear of the engine, more rearward and a bit lower than the distributor.
Here's an example, old starter and Toyota re-manufactured:
