Coolerman
- Joined
- Jan 5, 2004
- Threads
- 143
- Messages
- 6,766
- Location
- Paint Lick, KY
- Website
- www.globalsoftware-inc.com
$400.00 plus shipping
I bought this harness off E-Bay so that I could take it apart and document it for the purposes of possibly building new 72 harnesses. This harness was completely taken apart, documented, then repaired.
All connectors were soda blasted to clean them up. Most of the wires/connectors in the engine bay were replaced with new. All splices in harness were crimped then soldered and heat shrinked. Wires that were cut short else where have been extended with new wire to the proper length, and terminated with new connectors. A new fusible link was installed. Fuse block was soda blasted and will be populated with the correct, OEM COLORED, fuses. Harness was then tested under full load, then re-taped with non-adhesive harness tape.
See pic of harness below...
Note this does NOT include a rear chassis harness or any other sub-harness. I can build a new rear chassis harness to go with this for an additional $175.00. (Normally this rear harness is $225.00)
