CDan,
I checked the drawings for steel wheels as well and since it was also developed for the 80 Series, it is maxed out at around 1150kg.
SNIP
An interesting rule of thumb from fatigue testing is that if you reduce your load by 20%, the life will be extended approx. 3 times the original. So if I design a wheel for 500kg and 60,000miles and then only ever load it to a maximum of 400kg, it will last 180,000 miles. Or the reverse, if I increase the load to 600kg, it will only last 20,000 miles. Even more interesting is that aluminium and steel show the same relationship in most cases. It is possible to get "infinite" life from steel at very low loads, but when was the last time you removed weight from your Land Cruiser and kept it off?
Oh, yeah, when your girl left you because you prefer to spend your time with your truck...
SNIP
golgo,
Thanks, interesting rundown.
I certainly think the above explains the issues Blade is having. :whoops: He didn't bite on my dually comment.
Of course, Alco may save the day here. But once the wheels are no longer the weakest link, then the question is what breaks next?
like I said I am a see it in writing guy, if you want to come up with some docs, cool. Hopefully you can get some good wheel pushed through the current stuff has been terrible, like the current Tundra wheels. There isn't a single one from the work truck to the 1794 or Platinum that I would keep.
