- Joined
- Feb 23, 2005
- Threads
- 16
- Messages
- 1,081
Thanks Dan, will do..
spressomon said:Shotts,
Did you do the measuring for the shock extension for your 863's (to make sure they don't limit the spring travel and/or top out thus loading the mounts) or just kinda flying by the seat o'your pants (not that there is anything WRONG with that)?
SINCITY100 said:Oh..do you think the built-in hitch is strong enough for a portable winch (for self-recovery) ?
SINCITY100 said:Shotts...
Would you elaborate on that last comment..I am considering the Slee bumper, but I really want to know if it is worth THAT MUCH MONEY !
What is your overall opinion of its strength, fit, and ease of use (I.E. Spare/Hi-lift holder).. Thanks In advance !
Greg B said:Between Amando running the Rubicon and Shotts wheelin' his in AZ and Moab, I can't imagine that this setup of 863's and N101's isn't OK. Besides, I don't think it will hurt the shocks anyways. The front shocks are what limit the front travel. My guess is the rears are limited by the shocks even with 866's in there. What else is there to stop the flex? Swaybars maybe?
sleeoffroad said:On the 80 and the 100, the shock is supposed to be the limiting factor when extended. However fitting longer shocks you have to make sure you don't over compress them.
ShottsUZJ100 said:I'd not want my 100 any stiffer in the rear. (863)
Those 866's look like they'll be stiff unless you load up the back (gas tank/drawers, etc).
spressomon said:The 866's are great...even around town without all the hunting/camping gear (with my 100 set-up as is); no complaints other than lift...I just need a little more lift for normal loads and a bit more lift than that for heavier loads. I think the best thing for me to do is to add 15-20mm packer for levelling while running the rig without all the hunting/camping gear AND to add the air spring bladders to the coils to add more support for those once-in-awhile really heavy loads.
cruiseroutfit said:
ShottsUZJ100 said:Rear bump stops are lowered 2" in the 100 just like the 80.![]()
cruiseroutfit said:Not necessarily, as Slee mentioned, ARB lists them as a progressive spring, so for the first bit of spring movement (not 100% sure on how much movment), they are only 240 lbf/in, whereas your 863's are 250 lbf/in, most of your onroad suspension movement is rather small compared to offroad flexing... might actually be disirable? Someone try them out... we have used nothing but the 865's on installs here in SLC, might have to talk someone into the 866's soon![]()
Greg B said:Shotts,
If I understand him correctly, I think what Christo is saying is that the shock limits travel on the droop (extended) end of the axle. The bumpstop limits the uptravel (compression) end. If you use too long of a shock, the shock would be the limiter at compression instead of the bumpstop. And with the weight of the vehicle coming down hard this could damage the shock and/or mounts.
I too, would be very interested to know how much unused compressed length there is on the standard N101 shock. For instance, if there is 2 inches of remaining up-travel in the shock when the spring is fully compressed or the axle is hitting the bumpstops, then you could add an extension to the existing shock allowing 2 more inches of droop without affecting up-travel. This is a common practice on LR Discoveries and might be beneficial for us too.
ShottsUZJ100 said:I'm certain this is the same on the 100 though OME doesn't offer an L-shock because TECHNICALLY they don't offer a matching J-spring because the front can't be lifted to match.
sleeoffroad said:3. What are L shocks.
At the same SEMA meeting, we requested longer direct bolt in shocks for the 80 Series Land Cruiser. It took some convincing and a large stock order, but we finally got L shocks. They are 50mm longer on extension and about 20-30mm longer on compression. Again, as with the J springs these were intended for custom applications and not supported as a kit by ARB.
ShottsUZJ100 said:In my 80, after 3+ years of wheeling, I've never lost an 863. So, if the 863 is staying in and with an L-shock in an 80, why can't I use the same rear setup in the 100?
