82Blu noob here (2 Viewers)
St Louis MO, USA
Hi all!
I'm a noobie to ih8mud, but have been researching and reading here for years, including in the past with my 93 FZJ80... Finally got my first 40: 1982 CA Spec, with smog and factory AC. Needs a lot of love, but am jumping in and getting started.
First question: PO had partially disassembled and reassembled for sale... I can't find the connection to the brake pedal switch... switch is there, connector is dangling (with 2 green wires going to the connector) but can't find the mate. Should I look for it towards the fuse block? or towards the brake light in dash? or towards the eBrake handle? I'm assuming fuse block, but man, it's tight under there! :) I have wiring diagrams:
Thoughts?
Thanks!
So on my 72, I just flip 2 buckles and take out the drivers seat. Then I take an old sleeping bag fold it up and place it on the floor with some extra pillows. That way I can lay on my back and look up using a head lamp. Maybe the wire is in the loom but the connector was rip off by like a big foot trying to streach out a cramp.
(Speaking of big foot....) I'm 6'4" and >250 lbs so I appreciate the suggestion. :) -- Just 4 bolts for me... and, I need to clean out all the barn-find dirt from under there anyway.
Hi all!
Thoughts?
Thanks!
Figured it out... took out the dash cluster, found the mate up behind the dash cluster. This didn't fix my problem, however. Now I need to repair/replace the wiring as one of the POs spliced in dodgy trailer harness wiring, booger welded in a square receiver AND mounted what looks like an amplifier up under the bed.
Get yourself the correct toyota wiring diagram - it shows a lot more information than this one, and is almost completely correct ( unlike this one).
Also - if you don't have a multimeter then it's a good time to get one :)
