80 Series with Steel 40 Series 15 Wheels
YoYoHo
BJZ43 for Me !
Mountains
I was recently trying to find out if I could run factory 15 x 5.5 Steel Wheels on a 1994 and later 80 series with ABS and rear disc brakes.
The Information was little scarce so I figured I would fit up a set and get the answer for myself. Following that I thought I would post teh results here so other may benefit from it.
Vehicle is a 1994 80 Series FJZ80 ABS Rear Disc and Factory 16" Alloy Wheels
Wheels are FJ40 Factory OEM Steel rims from Toyota Current Stock - 42601-60072 - Steel Wheel
Tire is a BFG KM2 in a 33 x 10.5 x 15
Result is that they fit, only just but they clear and did not rub or need any clearance front or back.
The main reason for wanting to do this is builds like my BJZ43 where I am putting 40 series bodies onto 80 series Chassis.
They are close though so I would be linishing some casting down and throwing a 1/4" spacer in the truck tool bag in case I buckle one. But OEM Steel rims are very very thick compared to everything else.
Anyway hopefully this may help someone else who wants to run 15 steel sims and hubcaps on their 80
Bumping this…
Anyone else put 40 series wheels on an 80, particularly an early 80?
Just thinking about how that would fit and look. I think a wagon wheel would look good also, which would fit a 40 or a 60
Bumping this…
Not yet but thinking seriously about it. I’ve got some brand new IROCs (36x13.50r15) I bought for my Scrambler but thinking about putting these on my ‘94 FZJ. The pics look like they’re almost touching.
13.50s on a 5.5 inch wide rim might be pushing it.
The steel rims are 5.5” wide? I don’t think so. Isn’t the 5.5” measurement the diameter of the center hub opening and not the width of the rim?
Yep, factory 40 steelies are 15x5.5
