The 1.1 gears for “high” range affects both high and low range by changing the input ratio from the motor. Only possible because of the offset of both driveshafts. Land Rover transfercases used to come from factory with 1.2 and 1.4 input gears. It effectively does the same thing as changing axle gears.
@cruiseroutfit has a thread on these that explains in detail.
I have 1.1 with “34s” (285/75R
17). I was shocked at how noisy they are. (Turns out the gear cutter cheated by only providing 2 of the 3 gears).
I had my transfer case rebuilt and both 1.1 and 3.1 gears installed. The 1.1 gears are definitely audible above 30 mph, mine get louder with speed. Since I have to travel on 75-80 mph (actual speed limit) Interstate to go anywhere, the gear noise REALLY bothers me. I compare the the noise to mud tires but higher pitch and next to the driver so it’s more intrusive.
I have another FZJ80 also on 34s (34x10.5R17) and stock transfercase. So every few days I get a reminder of the baseline. There is definite noise and honesty I don’t notice a difference going up hills and all around driving. 1.1 just doesn’t really make a difference. I wish I would have kept the stock high range gears and saved up for 4.88 instead.
If you don’t mind mud tires on the highway, the gears likely won’t bother you.
