A great alternative to heavy duty sliders for the guy looking for good protection with a stealth look at a low cost. We have been trail testing and refining our Rock Rails for the last 2 years.
COST - $350 shipped in the 48 states
PayPal - MNIMARKETPLACE@gmail.com
Advantages over the normal heavy duty slider –
Light weight ~25lbs a set
High clearance 2”+ more clearance then heavy duty models
Nothing to get hung up on
Stealth look
No more dirt/mud on your pant leg or her dress getting in or out
Wife approved!
Price point about 1/3 of heavy duty sliders
Disadvantages over the normal heavy duty slider –
No steps
No pivoting off rocks
No cat protection
Not designed to come crashing down on rocks but strong enough to support the vehicles weight.
Do keep in mind that while these offer great protection in a lighter weight and high clearance friendly design, these are NOT a replacement for $1000+ sliders and do not offer the same protection of heavy duty sliders sold by Slee, Metal Tech and others.
Bottom line if you hit the Rock Rail once installed they just paid for themselves in savings on body damage.
In the first video the ledge on the left side is ~22” Listen 11 sec into the video for the sound when the rail makes contact. Resulting in no damage to the vehicle.
In the second video chances are using the same line the same truck with heavy duty sliders the would not of made it. Again no damage to the vehicle.
Pictured is the prototype (now 30% thicker) after it had been crushed by a rock on the unsupported area of the Rail. Amazing the vehicle received no damage.
They mount to the pinch weld in 5 location. They are primed 100%, prior to welding, then welded, and spot primed where welded. Mounting studs are tapped into the steel then Rosette welded. All metric 10.9 grade hardware with serrated flange JIS nuts. Steel construction tubing is .090 thick. End are plugged using plastic plugs.
Did I mention they are wife approved
Rails come primed and do need to be painted. Krylon Satin is a perfect match for black powder coat. We recommend spray over powder for easy touch up.
Tools required for installation-
Drill
Drill bits
Masking tape
Pencil
12MM wrench
Estimated installation time for the average guy 1 hour
Price point is $350 shipped to your door in 48 states
We currently have stock ready to ship and more on the way
PM me (New forum 'Start a Conversations'<click) for payment info
Stealth look
Wife approved!
No steps
No cat protection
Drill
Drill bits
Masking tape
Pencil
12MM wrench
