I never understand why things like brakes become a discussion topic.![]()
Kinda like women, each is their own.
This has been covered numerous times. Grogan, Chris, Rob?Considering a lift for the 80.
Looking at a set of Fox shocks here:
Fox Shox Front & Rear 3-4" Lift IFP Shocks for 89-97 Toyota Land Cruiser 80 4WD | eBay
Coupled with a set of Dobinsons 3" progressive springs on all 4 corners.
Thoughts?
Fresh 80 leather with seat coolers (and heaters) to keep your junk fresh
Best mod you can do if you live in the South!
Awesome work, my friend!They are, of course, available for purchase at my website or via phone/text/PM, but for more info, check out the thread in the 80 forum:
Seat Coolers
How the hell did you tear that up?Looking for a 1FZ alternator bracket. Need one ASAP.
Damn...To make a long story short:
Sometime during its previous ownership, it looks like someone went in to replace the alternator. In the process of attempting to remove it, they mangled the pivot bolt so badly, that no socket would fit on the end of it. I welded a nut to it, to no avail. Because the pivot bolt threads into the back of the alternator bracket, the alternator was essentialy l not able to be removed from the bracket itself.
The next step was attempting to remove the bracket and the alternator as one piece. The bracket is held in with two bolts. One bolt is easily accessible underneath the distributor, but the other boat is behind the alternator itself. Unfortunately, the alternator cannot be pivoted up high enough out of the way, to allow access to the second bolt. The next phase was cutting the bracket off at both ears. This was extremely difficult, as there are wires, sensors, and other various things on the backside of the bracket. Using an angle grinder with a 5 inch desk, I carefully cut the rear ear of the bracket off. I then used a 3 inch cut off wheel on the front ear.
Between both of the ears, I probably spent six hours removing that damn bracket. I could have gone much faster, but I would have endangered a lot of the forementioned parts.
I did get a new bracket from Noel, and when I installed it, I made sure to use lots of antisieze.
Of course, I also replaced the alternator with a Denso reman.
Basically, one hour job became a several afternoon job.
Thank you, Previous Owner.
