Does anyone know where I can source an 80 series clutch assembly for my swap? Or have any connections?
Thank youJapan4x4 will get you sorted quickly and easily.
I know every Part was available 2 years ago except brake pedal have to modify the stock 80 auto pedalDoes anyone know where I can source an 80 series clutch assembly for my swap? Or have any connections?
Sounds like a no nowNo, they are NLA.
Cheers
I think I found a guy that says he has a few coming inNo, they are NLA.
Cheers
Not new ones that is, but there are plenty of used ones aroundSounds like a no now
I don't believe soAre the Lh and Rh drive brackets the same?
I guess I’ll be looking for one then. Or try to mod a RHD to fit.I don't believe so
You can just have to cut the studs off , I prefer bolt in thoughI guess I’ll be looking for one then. Or try to mod a RHD to fit.
I might have a lead on one for youDoes anyone know a good source for LHD brake pedal/Clutch pedal and box? As noted all the NIB stuff is now NLA. I have tried a few sources for the LHD stuff but no dice. Does anyone have a good source they use?
Thanks
I am sorry it has taken me so long to respond. I'm not sure why it wouldn't let me log on for the longest time. At any rate if you have a lead, I'm all ears.I might have a lead on one for you
