80 series axle on a 60?
North Front Range, CO
Don't know about how to mount the axle but you will need to make your own wiring harness to lock the diff lock actuator.
For the rear actuator, Downey makes a cable kit to lock the actuator.
It work fine but if you live anywhere there is rust, you will need to replace the shift shaft with one made of SS.
I made a boot that goes over where the cable goes into the mounting block to keep it dry.
