80/100 seats in a 60
When I replaced my seats in my 60, I had a set of seats from a wrecked 97 FJ 80 and a set from a wrecked 99 FJ 100. Just an overview;
The 80 seats will come from model years 1991-97, 94-97 are slightly different than the 91-93. I tried to put a set of seats from a 99 FJ 100 into a 97 FJ 80 and it just took too much work to make it happen. I did use the FJ 100 seats in my current FJ 60 project vehicle. The 80 seats seem to mount higher than the 100 seats.
For the 60, the FJ 100 seats only have one excellent attachment point; front near the console for both seats, outside near the doors is ok, will need a little work but is ok, the rear attachment points will need to be created and need some steel added behind the holes. Another consideration for both, the travel of the 80 and 100 seats is different than the 60, a safety design to move the seat closer to being behind the B post and a change of the door opening positon between the 60 and the 80/100 series.
Follow the link in my signature if you want to see what some 100 seats look like in a 60.
That said, for the 60 seats from a 100 or an 80 leaves you a long way from the pedals. If you are tall it is not problem, I am quite comfortable but I am 6'1", more than a couple inches shorter will create some real problems for you.
In other words, my wife can't drive it but then again, that would suggest she would WANT to drive it which is NOT the case!
