79 BJ40 Knuckles = 79 FJ40 Knuckles?
BJ40 came with drums all around, are the knuckles the same? Can I run long fields with no problem? And will the mini brake components drop right on?
The birfs are the same and, if you see caliper ears on the knuckle housings, you are golden for the db swap.
My 77HJ had the drums with caliper ears on the knuckle housings, so I considered the swap myself. But, having adjusted the oversized drum brake system properly, I was HUGELY impressed by them, and decided against it.
Best
Mark A.
