I replaced the two fan belts on my truck a few months ago and in the process managed to misalign the smog pump pulley, causing a horrible screeching sound, and a I believe bearing damage. After spending the better part of a day trying to figure out how I had managed to misalign the pump with little luck, I decided to disconnect the pump by removing its belt.
Now I'm concerned that this will cause long term problems? Should I go through the hassle of attempting to rebuild the pump? Or just find a replacement from Napa, etc?
With all the rest of the emissions control equipment in place, is the lack of the air pump going to cause me long term damage?
I'd ultimately like the keep the truck as stock as possible, so will likely go about rebuilding the pump at some point, but want to know whether it should be sooner rather than later.
Thanks.
Thanks.
