This started when I rebuilt my carb. Truck was running ok before, but would occasionally diesel, and would occasionally stumble and have a rough idle.
I though it was carb rebuild time:
https://forum.ih8mud.com/threads/how-do-i-fix-a-warped-carb-air-horn.851676/
After the rebuild, I was unable to get the truck to idle without the choke fully engaged and after reading many threads, it seemed like a warped air horn, as shown in linked thread. After weeks of trying and not being able to get the truck to idle, in my exasperation, I broke into the secret vault and installed a NOS '74 Calif Spec Aisan carb. Yes, brand spankin' new --
AND still the truck would not idle unless the choke was fully on. Same as with other carb.
Checked multiple times:
Fuel level in sight-glass is spot on in the middle. Was with both carbs.
Idle solenoid is working on both carbs. Audible 'Click-Click'. Tried to run with 12V connected directly to solenoid, Still no idle without full choke. Checked engine fuse, ok, and also checked if there was power to the idle solenoid in 'engine run' condition'. Ok.
Checked extensively for Vacuum leaks with both Carb cleaner and injecting smoke (cigar) into intake manifold and no leaks that I can see - Engine pulls 15-16 Hg steady vacuum at idle with choke fully on.
Looking into carb venturi during running, it seems as though too much fuel is metering, but I really don't know what proper metering should look like. When I manually move the choke butterfly open, engine will slowly stall.
Things I have done, for no particular reason other than I was at the 'try anything' stage:
I suppose it's possible that both carbs could have Idle-Circuit issues, but ... ?
So any other suggestions of where to look would be GREATLY appreciated. I'm out of ideas.
Thank you...
- Checked spark, kind of orange, so New Coil/ w/ new external resistor. Still orange.
- New Distributor condenser (Dizzy is new non-USA vac advance unit - points look good)
- New OEM Fuel Pump
- New OE Fuel Filter
- Removed and cleaned Fuel return lines.
- Checked Evap system for blockages or pressure build up.
- Check compression - because there are no empirical signs of bad head gasket or compression loss. Coolant is clean and good. Oil clean.
Thank you...
