Hello this is my first message on this forum but i search it often. Just finishing a frame on resto for my 9/71 fj40. This is a long time family owned truck with no weird amateur wiring problems. My flashers were intermittent so from recommendations on here I cleaned the crazy expensive hazard switch and voila it works great. I did the same with the signal switch. Currently everything works fine and lights are bright and consistent. I have discovered if I have recently used the left turn signal, the right brake light doesn't work. If I use the right turn signal it starts working again. I had this problem before in an early 90's chevy and had to replace the turn signal switch in the column which was quite an undertaking. Signal switch? flasher relay? hazard switch(please no)? I have removed and refurbished or replaced all lights with attention to good grounds as that is clearly stated as the first thing to check. Thanks for the help.
