Ok, 1st lets talk about the stk wiring with the Toyota alt and the external VR. The alt wh/blue wire(WL) supplies voltage to the VR and fuse box and also connects to the neg side of the Ammeter. The positive side of the ammeter white(W) wire goes to the Batt. The wiring done this way shows discharge and charge+-. So, the alt is charging the batt thru the whole wiring harness thru a long 10GA wire. This is old and antiquated and imo dangerous. Disconnecting the ammeter is not really bypassing it, because you are still charging the batt thru the W/L & W wires. .
Bypassing the ammeter/WL/W wires would be running a wire from the GM alt post directly to the batt. The GM alt has an internal VR. The GM alt needs 12v to the #2 terminal on the plug. The easiest way to get the 12v is to loop the #2 terminal to the Alt's charging post. The #1 terminal is the sensing terminal. If your going to run and idiot light then run a wire from the #1 terminal to the light and hook the light to a source that's hot when the key is on or install a diode. I did what @pgbottle did in post #30 and used my brake light as an idiot light. My fuse box gets its power using the white wire with the fusible link hooked to the battery.
Below is how I hooked my GM alt on a 75 40. I disconnected the ammeter and connected those 2 wires together and made sure that connection can't be grounded. I have a 6ga wire going from the alt post to the batt +. The alt's plug has the #2 terminal wire/red wire looped to the alt post. The alt's plug #1 terminal/ blue wire goes to the idiot light. That lights 2nd wire makes a connection to a source that is hot when thr key is on. The single red wire on the batts + nut post connects to the white wire/fusible link feeding the fuse box. I followed the White/Blue into the harness a bit and terminated it with a butt connecter on the end of it, so it can't be accidently grounded because it's hot. I also taped up the end, then wrapped it into the harness.
