'71 Steering Column Splines? (1 Viewer)
Marietta, GA
I have a '71 40 (one piece steering shaft) that I needed to replace the steering box on. I made the box swap and found that the end of the shaft where the steering wheel attaches is larger than the one I pulled off. Were there two different types of wheels that fit on these early steering box/shafts?
yes, can’t remember exactly when but right in the 71ish models it went from the larger (36spline?) to the smaller 33 spline. Cheapest/Easiest would be to trade in your 71 wheel for an earlier version.
yes, can’t remember exactly when but right in the 71ish models it went from the larger (30spline?) to the smaller 33 spline. Cheapest/Easiest would be to trade in your 71 wheel for an earlier version.
Change date was 7/69 and went from.36 spline to 33 spline. Advantage of the 33 spline is Toyota used it on many models and until the 95 model FZJ80 with a airbag on all Land Cruisers. Even after 94 used 33 spline just all US steering wheels are made for a airbag.
I’m currently using an FJ60 wheel as a placeholder for my 12/71.
I am some what of a steering wheel junky. I first bought a gray 60 series steering wheel. Which is funny because at the time think the only 40 series I owned was my 68 FJ40 with 36 spline. I bought a 94 FZJ80 leather steering wheel to use on my FJ45 that planned to update to a later (73+) steering box. Then located a 8/80+ 40 series steering wheel. Then someone on mud was selling a gray FJ62 steering wheel cheap. Today I'm not sure how many steering wheels I have. I know I do span from a 1961 FJ40 to a 94 FZJ80. Only style I do not have is the early FJ55 steering wheel. If I ever found one of those would probably buy it as I have a number of early steering boxes it would fit so covered 36 or 33 spline.
Thanks guys. Off I go to the Classifieds to post a wanted ad for a 36 spline wheel.
- Farrell
