So I need a park brake set-up in my 74 40 because of the h55 install. Could not find the appropriate 40 axle but got a 70 series axle. From my reading there seems to be conflicting info. Some say they are the same dimension as the 40 some say 1-2 mm longer on the long side. I plan on putting my 40 shafts and 3rd in there to keep the 4:11. has anybody done this before? same axle bearing as the 40? If not the same length I should beable to remove the extra from the long side....right?
From my reading the axle splines are different from early 40 series to the 70 series 3rd so my 3rd would not work with the 70 series axle shafts?
Thanks,
Daryl
Thanks,
Daryl
The differance between the 2 housings is that the 70 is about 1 inch wider. Now this is where it gets weird...if you put the 40 series axle with the shafts installed next to the 70 series axle with the shafts installed the hub to hub measurement is only about 1/4 inch longer with the 70 series! The differance is where the 70 series backplate is mounted deeper over the axle housing.
