64 45 SWB floor boards
Lake Tahoe,
Anyone know where I can find 64 floor board replacements. The Only panels I can find are round ended the 64 floor panels are square.
Unfortunately I don’t believe anyone is reproducing 45 floor pans with the squared ribs. You could likely use the rounded ones and use a hammer and dolly to “ persuaded” them into being square. If not that a cut off wheel and welder would certainly fix it.
You can make them yourself, they are not that hard to do.
a basic bead roller some thick wall tube that fits over the shafts of the bead roller and large thick Washers.
You can add a layer between the outside washers to flatten the top of the bead.
just keep in mind that the deeper the ribs the more distortion of the part. As your part is flatwith absented edge on one side it should be fine. The distortion flattens out when you weld it to the tub.
All you need is a hammer to do this easy ribs :) ... not more.
If you want to see what real handmade is.... visit the Morgan factory in Malvern.
Just an example.....handmade louvers. Think it´s a bit more complicated to do them than the easy Toyota ribs.
... and if your handmade ribs are not as perfect as machine made ribs.
Who cares.... later you put rubber mats in ...anyway...
& nobody see it under your new stylish Toyota rubber mats. ;)
