6 pin voltage regulator wiring help (1 Viewer)
Aledo TX
I have the attached Voltage Regulator (Toyota 27700-54040-84) I’m attempting to wire into a harness I’m building for a 1982 FJ43. For the life of me, I can’t determine with certainty what wire is what and I’m asking to prevent frying the unit.
I believe (but looking to confirm) the following:
IG = red wire
N = White wire
F = Green wire
E = Yellow wire
L = Black wire
B = Blue wire
IG N F
E L B
And when looking at a 1982 wiring schematic, do both the IG and E go to ground/earth? Asking because earlier years (1980) did not ground the IG via a condenser...so I’m confused.
View attachment 1828079 View attachment 1828080 I have the attached Voltage Regulator (Toyota 27700-54040-84) I’m attempting to wire into a harness I’m building for a 1982 FJ43. For the life of me, I can’t determine with certainty what wire is what and I’m asking to prevent frying the unit.
IG = red wire
N = White wire
F = Green wire
E = Yellow wire
L = Black wire
B = Blue wire
IG N F
E L B
u do understand that the primary color wires on the 54040 regulator side are simply the Tracer stripe wire colors on the harness side
so solid yellow = white with a yellow tracer stripe
hope that helps ..........
But to my original problem: I’m building a wiring harness from scratch because the old one was bastardized by PO and doesn’t match specs (or anything close...it had a ford four pin VR). So I’m having to recreate the wheel.
I need to determine what color wire corresponds to what function: IG N E F B and N.
alot of this depends on what alternator u are running ?
do u have a factory EWD , Both USA & NON-USA
The big Tan Chassis Body FSM has some great diagrams that cover both applications #36044 & #36044E
Do U have a 30a AMP meter cluster
or
A 50a AMP meter cluster
u should have a 50A AMP on a FJ43L-KC 1982
off topic :
it looks like u have a Illuminated back-Lit knob Hazard switch in your photo just under your radio ?
I like the Peg board approach Very Much
or
I’m not sure honestly. It came with the charging indicator light next to the parking brake. I’m planning on wiring it to US specs as near as I can. My alternator is a 30amp.
I’m sorry: I have a 50 amp. Here are the specs.
New wire harness - Red wire w/ black tracer stripe : Interior Illumination
your old FJ43 harness had a solid green wire feeding the Cluster illumination ( most likley )
I was referring to your instrument cluster , regarding the AMP meter inside it
this should be what your after ?
let me know if this helps or not , I have other diagrams & Print Media FSM's EWD's for what your trying to do
Woke up to a hijacked thread. To get us back on track, I am asking the original question in another way:
I have the voltage regulator in this picture (borrowed from another thread) I am creating a new wire harness because old one didn’t exist and I’m starting from scratch. Help me identify the wires coming out
red wire = what?
White wire = what?
Green wire = what?
Yellow wire = what?
Black wire = what?
Blue wire = what?
They are what of the following choices?
IG N F
E L B
To answer any other questions, I have a 50 amp alternator and instrument cluster. The alternator has E F N and B connectors with an external voltage regulator pictured.
Thank you. You can direct message me with questions not related to the above.
