40 series general tech and classifieds
What was inside the cover when we pulled it off. SMH...
Well if I had known yall were going to work tonight I would have been there the crack open that diff.
Thank you guys for all your help.
so instead of the axle snapping, the stress point was the side gear?
Spotted at waynes tire in bay springs.
Clapped out hunting rig
Save those cool carnage award trophy parts!!!
Thanks
I have my 2F all back together finally after a nice HG vacation and set the front cylinder to TDC, dissy rotor to #4 plug.
Now, time to adjust the valves.
All the valve adjuster nuts are backed off. Oil holes seem lined up nicely. All of the rocker shaft holes are pointing straight up. Main oil hole pointing passenger side.
Some rocker arm clearance with the push rod is tight. Is this normal?
I found this cold spec valve adjustment. (any idea what the significance of the a,b,c and d listed in columns are pointing to?
Is this okay to use to set everything up?
FSM says rotate engine crank 360 aft adjusting the first 6 valves.
Is that just bumping the flywheel until timing mark completes one 360 rotation?
basically 180 out from TDC?
I think the a,b,c,d correlate to the order in which you lash the valves. So basically once you have the engine at TDC you can adjust all the valves marked a&b (also colored yellow). Then rotate the engine 360 and lash all the valves marked c&d (also colored in pink).
Yeah, the 360 just turns it 180 from TDC.
The a, b, c, d just look like some way to keep track of intake & exhaust.
@ntsaint , this is on the ham radio test, better pay attention!
Question, #1 firing piston is at plug #4 and #1 piston is the first by the radiator.
^ this.
With the flywheel at the timing mark, the number 1 cylinder should be real close to TDC. If it's on the compression stroke you can adjust valves 1,2,3,5,7,9. If not adjust valves 4,6,8,10,11,12...you've got a 50/50 shot. When you're done with the first group, turn the flywheel 360 degrees and adjust the other group.
The whole point the rotor to #4 cylinder has always been confusing to most people. This only works with stock dizzy or an aftermarket if set like the OEM. Most aftermarket HEI's are not marked with cylinder numbers so when installed at TDC rotor may or may not point to number one. To save time I always put the Trans in gear and push the truck instead of fighting with trying to get to the front of the crank to turn engine over.
Yea, I found this to be the best way also. Regardless if plugs are in or out...
Adjusting valves tonight and hope to fire it up. Have you ever used the cold spec above? Seeing how the engine is almost as old as me, the valve lash specs are probably out of tolerance for the wear on the engine. Although, all push rods are new.
Do you ever retorque head bolts anytime after new HG install?
