4.11 D60/14bolt gears
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
I have a set of D60/14bolt 4.11 gears in Vegas $100 for the pair.
Or trade for some Asin (sp) hubs???
Actually, the 4.11 D60 gearset is attatched to a carrier with a welded lockright in it.
Lockright shoudl be able to be warrantied fairly easily..
HI^C
14 bolt on a posi carrier? or RnP only
welded lockright warrentied? explain interested in this possibility.
lockright alone a possible?
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
Ring and pinion alone.. I needed the carrier for the cool sandy cone spool..
The lockright has had a piece of metal wedged in between the inner halves. then that piece of metal is tacked to the rest of the lockright (seriously booger tacked) It was slipping enough that I did not even have front wheel drive. It sucked ass..
I talked to PORC about it and they said I could probably warranty it.
If you want the lockright let me know.
It will be a bit of a PITA to remove from the carrier.
HI^C
you will need different carrier or thick gearset to go to a high num gear.
Ding ding see PM
