Not sure if anyone has posted this one yet
Are you saying we should PM replace the water pump at 60k?This is good as any thread, I suppose. To taking about the 3UR-fe. I'm hunting for: The Good, The Bad and The Ugly > which I'll post more of here. I encourage all to add to.
In above video tear down. We see a broken cam bolt out of a Tundra w/287K miles. A USA manufactured engine. Why did the bolt break and are we seeing more of same?
What are, the failure points we're seeing in the USA or Japanese manufactured 5.7L 3UR. That result. in blown engine?
Are the 3UR built in Japan, better or worst?
In the 4.7L 2UZ-fe, it was a USA manufactures, that we know of two of them reached 1 million miles. The first was run on dinno with score 98 out of 100. The engineers that tore it down. Said nothing was wrong with it. We known, the Japanese manufactures 4.7L 2UZ to be even better than the USA made. In that USA 4.7L 2UZ-fe was known, for busting rod and the Toyota tick (piston slap).
Toyota 5.7 V8 3UR-FE Engine Problems and Reliability
The 3UR-FE is the most reliable and durable engine for all UR engine family. The Toyota made over 1.3 million kilometers of durability testing for this engine. In reality, the 3UR-Fe can run more than 400,000 miles (650,000 km) smoothly with regular maintenance with using high-quality fuel and oil.
But nothing is perfect and this engine too. The 3UR-FE has a problem with coking of the piston oil rings which caused high oil consumption. After that, the oil consumption increases over time. To avoid this problem, use only the recommended high-quality oil and watch the oil level. The 3UR-FE crankcase ventilation system sensor fails hugely often, and electronic throttle system ETCS-i is not as reliable as it should be. The problem with water pump is also found in this engine. Like other UR engines, the 3UR-FE has a leaking water pump with short life about 60,000 miles (100,000 km).
3UR-FE 5.7L Engine - In-Depth Look at Design and Reliability
What is the 3UR-FE 5.7L Engine? Is it good or bad? Read about Toyota 3UR-FE 5.7L Engine design and features, its the most common problems and relaibility.www.motorreviewer.com
No. That last bit, is repost from article linked below it.Are you saying we should PM replace the water pump at 60k?
