- Thread starter
- #21
pump looks aftermarket? and no fuel sock.
You are so patient and helpful.
The fuel pump is fired from the circuit opening relay (COR) in the driver's kick panel. The COR is fired both from the starter signal (runs the fuel pump during starter cranking) and the flap in the AFM. This ensures that in the event of an accident, the fuel pump is shut down if the motor stalls.
I strongly suggest fixing the problem correctly.
Pin 14 of connector ID2 (the one in the driver's kick) is the FP hot lead. It changes color from red/green stripe on the FP side to red/black stripe on the COR side.
You should also verify that you're seeing a strong +12 at the check connector pin 8.
If you're getting 0VDC on B+ then the EFI relay is open/faulty or there's a real bad connection somewhere.
Have you verified that pin 2 of the EFI relay is getting a strong +12?
Have you checked continuity from pin 4 of the EFI relay to B+ on the check connector (pin 8)?
