ok after doing some research and some testing I think my problem is unique enough to warrant a new post. since last summer my bj60 12v 3b has been starting really rough. takes a couple times letting the glow plugs warm up for a good 10 seconds or more and a couple tries of turning it over for 5-10 seconds before it starts to even sputter. i would need to keep my foot to the floor and sometimes keep the starter turning to assist it for a few more seconds before it will take and not stall. you could literally hear it waking up one cylinder at a time. keep in mind this was happening equally in +15 or -10 celsius. always tons and tons of smoke (white-ish), fills up the yard. lots of black soot left in the snow behind the pipe. but it always started eventually and ran like a top once it warmed up. about a year ago, a good 6 months before all this started i did the following work;
cleaned the fuel tank and sediment filter
all new soft fuel lines
cleaned out all the hard lines
new fuel filter
new glow plugs 10.5v
had the injectors hydrosonic cleaned
new pre combustion cups
valves lapped
new headgasket
head was retorked after a couple heat cycles
recently new bosch primer pump (i can always push it forever and it never gets hard. is this right? it pushes fuel to the bleeder on the filter.
more recently, a couple weeks ago I did a little more investigating and found two of the plugs burnt out so i replaced them and it started right up! i thought great, problem solved, so stupid that i left it for so long. however, I maybe got one or two easy starts before it went back to really rough, smokey and difficult. so tonight i went out, pulled the glow plugs, they tested good, so i tested them off the bracket they normally connect to and although they light up slower than off the battery, they do get hot (took about 10 second instead of 3)
I also noticed a couple spots around the injectors that appeared slightly wet or rather just darker than dry. so I tried tightening all the connections above and the injectors themselves but they were all tight. I put it all back together and now it won't start at all, it just turns and turns, no sputters or anything. I want to double check my bus bar connections tomorrow with the volt meter, maybe something didn't reconnect properly there tonight. but if i find that i still think i will have a rough start issue
i seem to have a working time delay glow system, I gotta check voltage but it seems to supply nearly full voltage for 20 seconds or so and then shuts off completely. dash light is only on for 3 seconds though. there is no longer low voltage period so I don't think i have a super glow system (at least not a working one)
my gut says its an air getting into the fuel issue. could it be my injectors are sucking in air? or maybe the seat that goes down their hole isn't sealing it to the head properly? if air is getting in lets say around the sediment filter, would it migrate to the injectors to cause difficult starts until it is purged? i feel like in that scenario it should sit in the fuel lines until it reaches the injectors and then cause issues.
new fuel filter
valves lapped
new headgasket
