Hello all,
I've gone through a good portion of this forum and haven't found what I'm looking for - but let me know if there is some "please-read-first" that I've missed which explain the nuanced 3B heads and their part numbers. The documentation of my findings are below:
Similar to this thread:
forum.ih8mud.com
I am also from Canada, and also have a head with a 11111-58010 on it. Mine is from 1982.
From that thread, it was generally accepted that the 11111 = 11101, and the 58010 was interchangeable with 58011, 12, 13 and 14
This also seems to be true in the documentation here:
These are 41mm LARGE exhaust valve heads, with only 4 rocker cover bolts down the middle (as opposed to around the perimeter - which I'll get to in a moment)
You may be quick to say that the "large exhaust valve" indicates it is a "new" 3B head style, as opposed to the "old" style, found here:
These are known as "small valve" heads - and have 4 bolts down the centre to mount the rocker cover. And while the years for these are from 1974-84, and the 58010-14 large valves are from 1980-88, note that A: there is an overlap in years, and B: there is a third newer style which has not been discussed:
www.alibaba.com
These also have a large 41mm exhaust valves, but their rocker cover is bolted in place around the perimeter, and cover years from 1984-96. These are known as 58050 and 58051.
So just be weary when referring to "old" and "new" style heads, or even "small" or "large" valves, because from what I can tell there are at least 3 distinct 3B heads, and getting the wrong one will ruin your day.
1974-1984 - 59025, 59045, 59046, 59105, 59106, 56032, 56033, 56034 - small exhaust valve, rocker cover bolts in centre
1980-1988 - 58010, 58011, 58012, 58013, 58014 - large exhaust valve, rocker cover bolts in centre
1984-1996 - 58050, 58051 - large exhaust valve, rocker cover bolts around perimeter
Let me know if I'm wrong, so I can correct and make it easier for the next poor guy looking for a crack-free head.
Now, to see if I can track down a 58010-14... possibly direct from Chynah. wish me luck.
3b head serial number
Hey all. Ive been porting a head on a 3b and found that it had no cracks in between the valves so I thought it was aftermarket or something. I then tried to cross reference the serial on it and came up empty. Anyone else seen this number on a 3B head?
Cylinder Head 3B Large valve 08/1980-06/1988 [11101-58014] - $1,428.90 : CruiserParts, The best place for Land Cruiser Parts!
CruiserParts Cylinder Head 3B Large valve 08/1980-06/1988 [11101-58014] - Got a rare 3B in your cruiser and just cracked your head? Can't find one used? Here is a new head! The head is sold bare (precombustion chambers, freeze plugs & valve seats, stems are preinstalled!)This requires you to buy...
shop.cruiserparts.net
Cylinder Head B, 2B & 3B small valve 1974-1984 [11101-59105 / 11101-59106] - $999.00 : CruiserParts.net, Toyota Landcruiser Parts
CruiserParts.net Cylinder Head B, 2B & 3B small valve 1974-1984 [11101-59105 / 11101-59106] - Got a rare B, 2B or early type 3B (Smaller valve style 3B engines only) in your cruiser and just cracked your head? Can't find one used? Here is a new one with precombustion chambers installed! The head...
For Toyota Dyna Coaster Land Cruiser 3.4d 3b New Cylinder Head 11101-58050 11101-58051 - Buy 3b New,11101-58050,11101-58051 Product on Alibaba.com
