i need info asap. all help greatly appreciated. i tried to search. has anybody put 3.4 v6 in fj 40. i have some decisions to make quick. a pic of it or info on someone that has would help. thanks -ben
I think it'd be a great swap. Lots of SBC guys poo poo the idea, but it has roughly similar hp and torque numbers to a mid 80's stock carb'd SBC. A bit less torque. However, I'd bet on a dyno they'd be closer than you'd think because most back yard mechanics suck at tuning old carbs, and most old GM engines you'll find in landcruisers are way past their prime. That's not to say that a newer vortec 5.3 isn't going to have more power, but the 3.4 should be adequate.
I have no problem with the 3.4 in my 3rd gen 4runner and it's about 1,500 lbs heavier than an fj40. It tows my sailboat down the highway at 75mph without complaint. And that would be even more so with the swap. I'd guess you'll drop another 3-400 lbs.
And, if you ran an auto you should be able to bolt up a 80 series transfer case and be done with that issue. Plus with the short length of the engine you could put a doubler in there and still have a decent length rear drive shaft.
Anywho, I like the idea of a reliable, Toyota built, 3.4 in an fj40.
Personally I think something like a 4bt or better an Isuzu 4bd engine would be a bit cooler, but the 3.4 would be a nice fit too.
Far be it for me to say no way to unusual swaps, I did a BB cady into a FJ40But I would never advocate a small engine swapped into a heavy brick shaped vehicle.
201 hp (142 kW) at 4800 rpm
220 ft·lbs (298 Nm) of torque at 3600 rpm
vs a 8.5:1 350 chev with cast heads , cast pistons , solid rockers , solid cam , 4bbl carb .
310 hp at 4800 rpm
375ft-lbs at 4000rpm 350ft-lbs at 2000rpm
i really see a difference there in power . especially were it is at . the whole 350ft-lbs at 2000rpm part really helps .
however a 3.4 is personally the best v6 swap , its reliable as can be . if you don't plan on giant tires and like your 4.10's then it would be great . it sure beats the stock engine for power .
I've got the 3.4L in my Taco and I think it would be very unhappy with another 500lbs... in fact it usually was when I loaded it up with 500lbs or moreI usually lost 2-4 mpg
Just because the 3.4l makes as much as an older V8, doesn't mean it drives or feels the same. My Tacoma has as much if not more hp than my 5.0L TBI'd cruiser. But my 5.0L TBI'd cruiser with 35" tires and 4.11 gears would out pull my Taco with 31s everyday of the week while getting 15mpg on the freeway.
An overworked V6 will get as bad if not worse mileage than a V8 in the same platform. I doubt you will ever find a V8 swapper who said "damn, I wish I had less power" but I'm sure you will find more than a few V6 swappers who wish they had more
The reason this v8 guy "poopoo" the idea of swapping little engines is the money, time, effort, and support to do a small engine for "minimal" gain and an overworked engine.
Most Toyota engines will cost as much as their domestic V8 if not more.
While physical installation and time is similar for most swaps, you are still dealing with no aftermarket mounts for Toyota. Especially in a cruiser. What will kill you is the wiring and minimal support. There are dozens upon dozens of shops dealing with Vortecs, LSx, TBI, etc. I doubt there is more than a dozen Toyota swap shops. You have limited choices for aftermarket harnesses, programming, etc for toyota engines.
If the power numbers posted here for the 3.4 are correct,a 4.3 chevy would be a better v-6 option.
