- Joined
- Jan 28, 2008
- Threads
- 3
- Messages
- 17
Hi all,
I've got a 1991 2.4 LTD (2L-TE) Hilux Surf. I have another thread going on this topic, but it started out as something completely different, so I thought I'd start a new thread to deal with just this issue.
I've found that the engine is impossible to start below a certain temperature and have narrowed it down to a part on the fuel pump which I think is called the "spill control valve". There is no smoke or ignition at all.
From what I gather, this part is a solenoid that determines how much fuel the injectors receive, depending on fuel pressure. I've found that if I hold a hair dryer to it for a few minutes, the truck will start up immediately, with no problems at all. So, my theory is that there is a buildup of varnish or congealed diesel which makes the solenoid stick. When warmed slightly, it has the power to open the valve properly.
In any event, I'm now looking at replacing this part and was wondering if anyone knows:
a) Can it be removed from the fuel pump?
b) If so, how?
c) Can it be serviced (i.e. cleaned)?
d) How does it work?
I appreciate your thoughts.
For reference, a picture of what I think is the offending part is attached (not my pump, this one is a pic from the internet).
Cheers,
Max
how do you remove the metal cap on the SCV?
Having same problem starting my 2 LTE engine on my Prado. I have tried to swap pumps nothing changes. If it does start revs go straight up and won't stop with the key neither is there rev control on the pedal. It was all good until had it parked for a month. I suspect rodents may have gotten in and cut some cables. Will try checking cables from ignition and from the pump to the ECU. Anyone here to help I would appreciate. Am from Zambia. I have been all over internet to just sort this out.Hi all,
b) If so, how?
Cheers,
Max
Here are the LJ78 schematics translated to english (below). They should help you to check your wiring.
Check your throttle position sensor wiring, and the spill valve wiring especially. Try a different ECU if you can.
Make sure not to put 12VDC direct to your spill valve, or you will burn it out! It is not like a fuel shut off solenoid of a mechanical injection pump.
Check to see if anyone has increase fuel by screwing in the adjust on top of the spill valve. The engine will go into run-away if this is screwed in by one turn or more. If this has been played with, screw it back out and it might fix your problem. It should have a cap cover it. If the cap is removed, then likely someone has played with it.
Also, you should read out the engine error codes. You have to jumper TE1 to E1 in the diagnostic connector box in the engine bay. The check engine light will flash codes with key turned to 'ON'.
Also read the ECD manual so you understand the engine:
Here are the schematics:
