John, does the Denso injector pump on this engine also have a small mesh screen inside the banjo fitting on the intake line to the pump? .
Yes
Hi everyone,
It appears that the timing belt jumped at cog on the crank shaft and that is what has been causing the problem.
I now have a new problem. The crank pulley, which was just replaced because it had been broken, has a crack in the key way. Apparently the replacement key wasn't quite wide enough and the play has caused a fatigue crack through the keyway. We're going to attempt a weld of the crack and then sweating a collar on the outside of the pulley to prevent it from happening again.
Anybody had the same problem?
Klemwild
