I have finally had time to look into this problem again. Things I have tried, engine has a fresh rebuild maybe 2000 miles
Compression test (Good) (540) on all
Two different (used) sets of injectors
Rockers good but not great (old 2h rockers were a lot worse and didn’t make this noise)
Change oil and cut open oil filter (no metal)
IP Timing is spot on
No exhaust leaks that I can find
Fuel piping hold down rubber is good
I’m sure there are more I’m forgetting. I have posted a video on YouTube but not sure how to link it here. Title is “Toyota 2h ticking noise”
The noise only shows up after engine is warm. Can’t hear it below 1800-2000 rpm, gets louder the higher the rpm. After the engine is warm it will make the noise whether driving or sitting still. The clutch in or out doesn’t effect it. I am leaning toward new injectors, lifters, pushrods, rockers or all the above. I would like to pin point the problem before throwing parts at it. The above parts are the only ones that were not replaced on the rebuild.
I would really appreciate any help or ideas.
Thanks,
Brian
