2H oil consumption (2 Viewers)
Tbilisi, Georgia (Sakartvelo)
Hi everyone.
Have a 1989 HJ60 with a 2H in it, 24V system.
Bought the vehicle at 299k km in December 2024, now it's 308'500-ish km. Changed oil twice, aside from the burning. 15W40 diesel-fleet semi-synthetic. For the last 3-4k km or so it burns about 2 liters of oil per 1000km, which I regularly top off.
There were 2 incidents prior to this:
1) The oil filter that came with the car was seeping oil badly from its own seam (Probably cheap/overtightened). I noticed it only during the oil change and ended up using a welder to make the base of the filter NOT stay in place while turning the filter would just turn the cup. Ok, replaced it and thought that my oil consumption problems were solved (as the next 2000 km showed, I was happy and very proud of myself).
2) However, during the same oil change I decided to blow some dust off the air filter the previous owner installed as well. Did it, reinstalled and drove for another 2k km. Just of curiosity, opened up the air cleaner box and... Saw lumps of oily white-gray dust past the lower rubber gasket (yes there is some oil in the intake). Noticed that the filter itself wasn't original, since the PO modded it to fit by cutting the inner "neck" of the filter element. My mistake was not noticing it and not installing the filter as concentric to the airbox as possible.
So the engine was breathing dust for about 2k km.
After that I started to pay really close attention to the oil consumption, which ended up being the numbers I gave above.
Other than that:
Had some cold start issues (at 0-5°C) since the purchase, as someone would just cut off the fuel suddenly. Heating up the glow plugs couple times or adding some throttle for maybe 5-10s and letting go helps this issue.
Did a cold engine compression test with a 40$ chinese diesel compressor kit, here are the numbers for each cylinder in bars:
1 - 28
2 - 28
3 - 29
4 - 28
5 - 27
6 - 28
Keep in mind that since my tester doesn't have a valve at the end of each adapter, it enlarges the effective combustion chamber volume by the length of the hose and the adapter, so I would throw +1 bar for each measurement. However, I didn't test the tester itself with another gauge.
Did manage to put a boreacope through the pre-chamber. On all 6 cylinders in the upper section past the rings – some hefty gouging and black burned oil residure. However, looks pretty ok below the top dead ring stop point. Some scorring, yes, but nothing I personally would consider critical. Honing looks ok. Only 2 valves are leaking (#4 and #5 intake ones), the rest are good. I was hoping for the valve stem seals to fail but no luck.
Some more data:
I live in a mountaneous city with heavy traffic and use the car 3 days a week on average. Trying to avoid the traffic in early/late hours but it's not always an option. Riding on 31" wheels, 37:10 stock diffs. Climbs over 10% incline are a high-rev pain. Overtaking pretty much anything modern isn't an option. No tachometer yet, the car didn't have it and I still didn't install the sensor. But I measured the rpms with a handheld thingy, and judging by the sound I don't go past 3k rpm.
So I don't understand – how can I still have such great compression numbers but also such a warning oil consumption? I've read here something about the failing oil control ring lands on the pistons, but that usually leads to deep long grooves the entire travel of the piston on the cylinders which I didn't see at all.
If it helps I'll post the borescoping photos, but as the next message.
Besides the obvious advice like a full rebuild (which will take a lot of time, and that's my only car currently), can anyone else say some reasonable thoughts on how to diagnose this further?
P.S.: rear main crank seal also seeps noticeable amount of oil, and I will change it while installing the tach sensor, but I doubt it contributes to the consumption so much as I described.
What is the blowby like on this engine? Lift the oil fill cap when its running, for reference below is two videos showing the extremes of blowby, good and bad. For whatever reason some people find full mineral oil burns less in 2H, I have no plausible explanation why this might be the case.
Bad
Good
Bad
Good
I guess mine is kind of in the middle?
I did the cap test couple weeks prior to borescoping, the vapor is definitely there but not enough to make the unscrewed cap move even a bit on idle. Didn't check on other RPMs though.
I'm probably gonna try pure mineral 15w-40 next time, when I'm done through the remaining 13L of semi-synthetic I already have :)
Interesting.. I'd expect that to be around 1L/1000klms.. try blocking off the hose from the valve cover to the intake manifold and revving it to 2000rpm or so. I think a clearer picture is emerging.
Here's the characteristic gouging past the rings of the cyl #2 (don't want to spam here with pretty much the same images). Same pattern is present on all of them to a larger or lesser extent.
The #1 seems having it the worst, gouging + accumulated oil that is just dripping.
But, again, no excessive scratches on the rings travel path itself.
Oh, one more thing, and it's a really weird one.
It's like my 2H has a secret oil compartment inside the engine that he sometimes decides to dump into the sump :)
Goes like this. On cold, I check the dipstick and the level is at LOW. I add 1 liter, it gets to FULL.
Then I drive for maybe a couple days, ≈100km.
Check the dipstick again, on cold – it's above FULL.
Maybe I'm doing something wrong, but that throws off my measurements sometimes.
I find the 2H is quite sensitive to the level of the vehicle when checking oil.. minor changes in how the vehicle is sitting can give quite different readings on the dip stick
I recorded a short video (available via link, but not public).
There is definitely blowby when I block the PCV port with my thumb, but I don't have enough experience to say how much blowby is it.
What's your take on it?
P.S.: Somehow youtube placed it straight to "shorts", maybe because it's vertical.
It certainly doesnt seem bad.. not bad enough to explain your reported oil consumption.. I would sort of expect that to consume some oil though.
I'm no expert on the 2H, but to me that engine sounds pretty rough for an inline six. Or does it sound smooth once it is hot?
Those are interesting scratches on the bores, looks like there is some foreign (or broken ring) material riding on top of the top compression ring.
If the engine runs rough when hot and the injectors are good, I would start to wonder about the condition of the pistons/rings. The excessive oil on the walls of the bores might be masking low compression results.
My glow plugs aren't currently working because they stopped turning off (another issue I'm yet to diagnose, unrelated to oil consumption). That's why it's rough in cold. Warmed up it runs ok, although noticeably vibrates on idle.
Yeah I noted them too, because on the ring travel path there aren't continuing, at least that excessively. A friend of mine joked that I caught a sparrow in the intake :)
I'm yet to pop-test the injectors, but they've been changed to new ones supposed no more than 30k km ago. And it does run ok when bot, so I doubt they're the problem. I'll still test them though for both the opening pressure and the spray pattern.
If these happen to be the rings, is it possible to swap them from the bottom of the engine (through the oil pan) without pulling up the head? I've never rebuilt one personally.
No, pistons can only be removed from the top of the block.
If the engine is running OK and the oil consumption not too excessive (2 litres per 1000 km is quite a lot in my opinion, others may disagree) I wouldn't start stripping it down immediately. Maybe someone more experienced than myself can give a better theory for the strange vertical scratches and ring wear. But with all the symptoms together, it seems your engine is due a rebuid in the not too distant future.
I know but I hoped I could delay it for maybe couple of years. In any case, whatever the further diagnostics reveal, I'm gonna concentrate on getting my other car in a driveable state to not leave myself stranded. And till the rebuild of my 2H I'm just gonna have to feed it the oil it wants and hope it doesn't get any worse. Maybe even get the engine bay with all the bells and whistles around it to keep the future rebuilt engine happy :)
I can live with 2L/1000km, for me that's just two extra oil changes per year in terms of oil quantity.
In regards to my engine starting rough, aside from the disconnected glow plugs circuit – my batteries are dying, so during startup there's a huge current draw that the alternator tires to supply to charge the batteries back up.
There are multiple issues I have to address in this car being the age it is, trying to keep fixing it bit by bit, but an engine rebuild feels like gonna take a month or six
