- Joined
- Jan 24, 2003
- Threads
- 144
- Messages
- 2,024
- Location
- Columbia, MO
- Website
- www.tornadoalleycruisers.com
Howdy:
working on re-gakseting a 1978 2F with 106K on it. Backround: had sat dormant for 10 years before I got the truck. After setting valves and timing, it fired right up. Showed 150 compression on all 6 holes after running to operating temp...
Pretty standard teardown til I pulled the balancer. While it did not wobble on the crankshaft, both the crank keyway and balancer slot exhibit some scary looking wear. The key itself looks fine, and still sits tight in the keyway despite the way things look. The motor seems as tho it has not been messed with, but maybe the balancer nut worked loose earlier in it's life, necessitating a new front mainseal? The crank nut was on *tight!*
The question: reassemble and carry on? Reassemble with a spare balancer that seems less worn I might have laying around? Or, am I totally fawked?
