ntsqd
technerd
I have yet to find, after about 30 minutes of searching, what the FSM recommends for oil pressure. I've found no schematic of the oiling system. The only FSM portion that I haven't looked in is the Emissions manual.
I put a direct mechanical gauge in the port where the sender was and I get 4 psi. Doesn't matter that the engine is doing (hot idle, choke high speed idle, free rev'd) it reads 4 psi. The gauge goes to zero when the engine is shut off. It did spend some time on a small diesel engine so it could be screwed up, but when on that little engine it did read more than 4 psi. I have not yet found another gauge that I can put in it's place.
Any thoughts or ideas?
