Well, I've dug on the forum and found good part numbers for what Im looking for but I cant find them ANYWHERE.
Long story longer, rebuilding 2F, crank turned 10 under. OrderTiaho bearings for the correct size form Yota1 but turns out the Thust bearing face is also apparently oversized because crank does not fit.
Im dead in the water until I find pn for the clevite bearing with .25mm undersized diameter and stock thrust width is MS-2087 P-.25mm Any suggestions or leads would be great! Everything I see online ships mid or late August....if that is even reality. I figured there should be a set somewhere out there. Thanks!...
