- Thread starter
- #21
Good Luck! Sounds like you're on the right track by putting a lot of thought into it up front. I megasquirted a 1970 BMW 2002 a couple years ago and it runs terrific! More power and much better gas mileage.
I don't think you need 4 bar map sensors though, that's a bit overkill, those are normally used for turbo or supercharged applications. But in any case, having two map sensors is a great idea since you live in high altitude, that way the system will compensate on the fly, not just when you power up the ECU.
You might consider installing a Ford EDIS ignition. It's pretty much plug and play after you figure out how to mount a toothed wheel on your crank pulley, then you can optimize your spark advance as well as your fueling.
Tuning should be pretty easy on a 2F...
thanks
The directions indicated the need for the dual MAP if in mountainous area, as I definitely am in the "hills", and I have traveled from 2,000 feet (southern Utah) to 10,000 feet (Henry Mountains area) in a single day run. I have the need.
As for the ignition I want to do that, but definitely do not understand (yet) the 36 point wheel and pickup sensor. I like to understand the theory of operation as I do things. If I don't understand, it becomes harder for me to the small things.
Then again, I just might be making bigger than it really is, since I don't fully understand it and how to put a differ dizzy in the rig etc. I just need to review and review some more other's projects
