or make sure the PCV system isnt plugged. I've seen people block off the PCV before not knowing what it does...then as a result oil gets forced past the rings.check the pcv valve isn't stuck open
Oil accumulating in the pcv piping and then getting sucked in under high vacuum would explain this symptom.
