- Joined
- Jul 22, 2012
- Threads
- 630
- Messages
- 17,204
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
- Location
- United States
Looking to buy at least two inspection covers for 2F bellhousings.
Are they just slightly off from each other?The 40 series has a slightly different bolt hole configuration than the 60 series.
I have a couple of each.![]()
Don’t you have some hubcaps to cut up?I can’t remember either, If I get a chance today I’ll pull each of those bell housings and compare.
Don’t you have some hubcaps to cut up?![]()
No hubcaps to cut yet.Don’t you have some hubcaps to cut up?![]()
There is a difference in the 4-speed bell housing’s.
The first photo, my gloves are pointing to an area that is not the same.
Third photo notice the dust cover attachment holes have one different.
Second photo shows an 1978 cover, the hole layout is different than the later bell housing.
I hope this helps with your search.
Good luck! John
Top is later81 up, bolt hole around corner
bottom early 74-80, IIRC
Note top left corners in pic
You ever get what you need? I have one from a 78 and just found one off a 79.
