SOLD 2F & 3FE parts dump! Exhaust Manifold, Intake manifold (2 Viewers)
Alaska
EDIT: With magic I've found a way to include photos
Hey folks, I have accumulated a massive amount of parts from my 2FE build; I've tried my best to tabulate everything and put it in a folder -
I will edit this list as things get picked up. FYI I live in Alaska, but I will work with you on shipping - help me clean out my garage.
2F Parts (Was desmogged for a couple of months before finding donor 3FE parts):
Carburetor (OE, not tuned) 21100-61142
Air Intake & Filter (w Desmog caps)
Carb cooler 16360-61015
Valve Train
Head with springs & valves
Spaghetti monster (Vacuum lines)
Steering pump
Fan Clutch
HAC Valve
Bimetal Valve 90925-05046 Pending
Bimetal Valve 90925-05035 Pending
VCV 90925-03058
VTV 90925-01014 (2)
EGR Vacuum Modulator 25870-61011
Thermostat (plugged) Pending
Distributor 19100-61102
Exhaust Manifold
Intake Manifold with valve
JimC Smog Pump Delete Pullet
VSV 89570-60070
ASV Valve 135200-0350
Smog Parts-
EGR Valve 25630-01110 & Tubing, EGR Vacuum modulator 25870-61020
Smog pump! (Was functioning before desmog) 17610-61030
Vacuum Switch Valves – 2 mounted
Air Injection Rail
3FE Parts -
Intake Manifold Plenum
Intake-to-head Manifold
Block – SN 0165659. Looks to be in good condition
Exhaust Manifold (both parts, all 3 shields total) !
Crank
ECU 89661-60021
Fuel Injection Rail, heat shield
Bellhousing adapter
Flywheel
Timing Cover
Timing Plate
Fan w/ Clutch
Air Pump 17610-61040
Thermostat housing, Pending
Metal Coolant Hoses
Idler Pulley
Crank Pulley
Smog Pump Denso 17610-61040
Valve Cover (2)
Oil Cooler (kinked, see pictures)
Filter & Pressure sender housing
AC Compressor, Condensor, Lines
Vacuum air Diverter 26710-61030
Air Injector Rail (2)
Water Pump (2)
EGR Tubing (2)
Smog Silencer Canister (2)
Charcoal Canister
Fan Pulley
Oil Pump
Other Parts-
H4 Transmission 1986. In great condition (upgrading to H55)
Front Bumper FJ60 1986 – Left bracket for cap damaged
1986 FJ60 Coin Tray
Greasable leaf spring ends
Thank you for taking a look. Shoot me a PM for any additional photos or questions.
Regards,
Adam
Price for the 2F Smog Pump and Timing Cover (2F/3F) shipped to So Cal 91316 ?
Thanks.
I’m not in dire need to the timing cover so I’m good.
I honestly have no idea on the valve. All I know is a I can buy a new aftermarket one from cruiserparts for $49 so I’d offer $25 shipped for the one in better condition. Is there a way to test it?
Interested in the 3fe intake to head manifold with the fuel injectors and rails. Shipping to Florida
Interested in the 3FE Exhaust Manifold (both parts, all 3 shields total), but realize that shipping from AK may be expensive - how much for these? Thanks.
Interested in the 2F exhaust manifold, and (less important, but still interested) in the intake one, too, since that would mean getting a pair that could be machined together. Can you PM me a price for just the exhaust and what you'd like for both manifolds, shipped to 83843?
Interested in the outer 3fe timing cover if @AlaskaOverland passes. https://i.ibb.co/FWwHYpD/3-FE-Timing-Cover.jpg
I think @Spike Strip wanted the timing plate based on the pic he posted.
I’m also looking for this guy for a 3fe. I didn’t see it listed but figured I’d ask since you had a lot of smog parts.
View attachment 2508384View attachment 2508385
FYI, I bought one on Rock Auto that worked. Think I found the thread size on Napa site and dug through Toyota models till I found a thread match and the hose size was close enough to work. Wasn't perfect but it passes smog.
Did you sell the 3FE exhaust manifolds and shields?
If not, cost+shipping to 81637?
Thanks
EDIT :Never mind, all set for now
Valve Train
Steering pump
Fan Clutch
HAC Valve
VCV 90925-03058
VTV 90925-01014 (2)
Exhaust Manifold
VSV 89570-60070
Smog Parts-
Air Injection Rail
3FE Parts -
Crank
ECU 89661-60021
Bellhousing adapter
Flywheel
Timing Cover
Timing Plate
Fan w/ Clutch
Metal Coolant Hoses
Idler Pulley
Crank Pulley
Valve Cover (2)
Water Pump (2)
EGR Tubing (2)
Charcoal Canister
Fan Pulley
Oil Pump
Other Parts-
1986 FJ60 Coin Tray
Regards,
Adam
Looking for a good serviceable 61030 Head. Cost + shipping to 20175?
